Que se necesita para convertir un baja 5b ss en un 5sc
Pues despues de que compre mi baja 5b me gustaria saber todo lo necesario para convertirlo en un 5sc, ya que me gusta mucho y alomejor me animo.
Haber si entre todos podemos poner todas las piezas necesarias tanto parte de carroceria como parte de ciclo.
Asi este post le podra servir a mas gente. Ahora me lio a buscar info para ponerla
PARA PASAR DE UN 5B A UN 5T
PARTES DEL CHASIS
Engine Guard # 85246
Body Mount Set Side # 85419
Stone Guard # 85247
Under Guard # 85425
5T Roof Guard # 85441
Body Mount Set FR/RR # 85417
Bumper Skid Plate # 85421
5T Bumper Guard Set # 85423
LLANTAS
Front Wheel Black # 3331
Rear Wheel Black # 3336
NEUMATICOS
Front Desert Buster Radial # 4437
Rear Desert Buster Arrow Tire # 4440
ESPUMAS
HPI Front Inner Foam Soft/190x60mm #4804
Rear Molded Inner Foam # 4818
AROS LLANTAS
HD Beadlocks # 3242 (you will need to order x2)
Beadlock Screws
Beadlock Screws x25 # Z340 (you will need to order x4)
CARROCERIA
Baja 5T Clear Truck Body # 7561
ENGRANAJES
HPI Drive Gear 19 Tooth #86482
CONVERTIR UN 5T EN UN 5SC
PARTES VISUALES
Baja 5SC Truck Painted Body Black #105330
Baja 5SC Truck Painted Body Red #105328
Rear Bumper Brace Set A #104779
Rear Bumper Brace Set B #104960
Bumper Set #104782
Mud Flap Set #104969
Step Screw M5x20mm (8Pcs) #86974
TP. Flat Head Screw M4X18mm (Hex Socket/10Pcs) #94632
Button Head Screw M5x12mm (6pcs) 3.0mm Hex Socket #94754
Cap Head Screw M4x25mm (6pcs) 3.0mm Hex Socket ##94510
Lock Nut M4 (4 Pcs) #Z664
Flange Lock Nut M4 (4Pcs) #Z684
TR-10 Rear Wheel Black #104971
TR-10 Front Wheel Black #104975
HB RODEOO TIRE Front/2pcs) #67865
HB RODEOO TIRE Rear/2pcs) #67867
PARTES INTERNAS PARA UNA VERSION COMPLETA
Rear Hub Carrier Set #104781
Super Heavy Duty Drive Shaft #104966
Super Heavy Duty Diff Cup #104965
Super Heavy Duty Drive Axle 25x70 #104967
24mm HD FRONT HEX HUB (GUNMETAL) #105612
HD FRONT HUB NUT #105613
SET SCREW M5x8mm (4pcs) #104964
PARTES DEL CHASIS
Stone Guard # 85247
Under Guard # 85425
LLANTAS
NEUMATICOS
ESPUMAS
AROS LLANTAS
Beadlock Screws
CARROCERIA
ENGRANAJES
PARTES VISUALES
Bumper Set #104782
Última edición por Jou el Jue Nov 10, 2011 8:27 pm, editado 6 veces
Jou- Mensajes : 69
Re: Que se necesita para convertir un baja 5b ss en un 5sc
Hola, aqui tienes como lo hizo Peter en su dia:
http://www.hpibajaespana.com/t790-historia-de-una-transformacion-de-5b-a-5t
Yo tambien lo hice en su dia:
http://www.hpibajaespana.com/t158p300-bricos-en-mi-baja
entre unos y otros ya sacaras conclusiones.
Ok, gracias por los post, ya los vi. He encontrado un post en ingles donde lo explican todo, lo pongo y lo ire traduciendo ok
Jou- Mensajes : 69
Buena aportacion
enriquevtx escribió:Buena aportacion
Ahora solo falta traducir.... lo hare poco a poco. Lo suyo seria imagenes tambien jejejej
Jou- Mensajes : 69
Bueno he estado poniendo algunas imagenes y mirando precios en una pagina americana.
Pasar un 5b a un 5sc sin las partes "internas" cuesta 529 $
Pasar un 5b a un 5sc completo cuesta 696,9 $
La verdad que es un dinerito jejej, pero buenosi quieres un 5sc de segundamano apenas se encuentran. Ahora convertir el 5b a 5sc sale en una pasta....
Jou- Mensajes : 69
La carrocería sale por unos 170€ (que es lo más caro)
Las ruedas (si no mantienes las del 5b) te salen por unos 140€ (también las hay usadas a buen precio)
El resto de piezas por unos 200€ más ya lo tienes... es cosa de tirar de ebay y comparar precios
Algunas veces salen cosillas de segunda mano muy interesantes,con que te hagas con todo el kit de soportes y la carroceria,lo demas puedes ir mas poco a poco,pero hay que estar al loro........ Es muy posible que pronto salga un kit del amigo joseofna en venta, asi que estar pendientes, la carroceria es la mia de monster.
enriquevtx escribió:Algunas veces salen cosillas de segunda mano muy interesantes,con que te hagas con todo el kit de soportes y la carroceria,lo demas puedes ir mas poco a poco,pero hay que estar al loro........ Es muy posible que pronto salga un kit del amigo joseofna en venta, asi que estar pendientes, la carroceria es la mia de monster.
pues que me lo diga antes de ponerla a la venta
gracias
Jou- Mensajes : 69
» Qué se necesita para...??
» Novato necesita ayuda!!
» Se necesita una opinión pública para un miembro
