Ddiferencias 5SC Y 5SC SS
BAJA1000
Hola , podeis citar las diferencias mecanicas de ambos modelos, sin ser que el SS venga desmontado y sin emisora y el precio? gracias
BAJA1000- Mensajes : 29
Fecha de inscripción : 20/03/2011
Re: Ddiferencias 5SC Y 5SC SS
Creo que no hay mas diferencias,montado o kit,con o sin emisora,con o sin servos,precio y poco mas.
No es lo mismo que el baja 5b o el ss, que aqui si hay diferencias de bastagos de amortiguadores,diferencial,etc..
el sc SS trae de serie la cola de cerdo ( tubo de escape de aluminio) no se si sabras cual es y da muy buen rendimiento no se si algo mas trae ademas de venir desmontado y de electronica solo te viene el servo de dierccion con piñoneria metalica todo los demas se lo pones a tu gusto emisora, receptor , servo baterias..
Baja 5SC SS FEATURES:
HEAVY DUTY FRONT WHEEL HUBS
To keep in sync with the new super heavy duty drivetrain, the Baja 5SC SS also comes with new Heavy Duty front wheel hubs. These new axles utilize a screw and nut design that eliminates the previous use of an e-clip, which furthers the reliability of the truck.
VISCOUS TORQUE DIFF
Unique in the world of large-scale racing, the HPI Viscous Torque Differential gets the power to the rear wheels as smooth as silk. It's easy to tune with optional diff oils and is fully fitted with hardened metal gears and an alloy case.
ALL METAL GEAR TRANSMISSION
From the input shaft and idler gear to the alloy-encased differential, every gear inside the sturdy Baja 5SC SS transmission is made from long-life alloy to keep your truck running all day long with minimal maintenance.
LONG TRAVEL SUSPENSION
The awesome Baja suspension really comes into its own with long-stroke VVC/HD shock absorbers and high-sidewall truck tires, letting the tires do their business whether you're driving over rutted-out whoops or flying over a big tabletop!
HEAVY DUTY SHOCK ABSORBERS
VVC/HD shocks deliver improved handling over rough terrain and feature large 6mm diameter shock shafts for increased durability. Threaded shock bodies are used for easy adjustment of ride height.
DUAL VENTED DISC BRAKES
Steel/aluminum hybrid brake rotors and semi-metallic brake pads handle braking duties, while a special venting system keeps the brakes cool for consistent stopping power.
LARGE 700cc FUEL TANK
For runtimes of up to 45 minutes, the Baja 5SC SS fuel tank holds up to 700cc of pre-mixed fuel - that's over half a liter! And just in case you clip a track barrier and flip over, the tank is equipped with a 'clunk' device that allows the engine to continue running even if the truck is resting on its roof.
SFL-11MG SERVO
The hi-torque SFL-11MG servo features extra tough all metal gears for durability, an aluminum steering arm and a water resistant case.
SEALED RADIO BOX
An enclosed radio box keeps water and dirt away from the 2.4GHz receiver and receiver battery. The on/off switch and recharging jack are sealed with soft rubber plugs for additional protection. To keep up with those long runtimes, a high capacity, long lasting, 3000mAh Ni-MH rechargeable receiver pack comes standard from the factory. It comes prewired with a separate charging lead for easy access charging with the included wall charger for that ultimate all-in-one package!
DIRT GUARDS
The Baja 5SC SS SS has full-length dirt guards to keep mud, rocks and water out of the main chassis area. The guards continue all the way to the engine and help keep cleaning time to a minimum. And, mud flaps on the rear bumper add to the realistic Short Course appearance.
BAJA 5SC FEATURES:
FUELIE 26 ENGINE
The powerful Fuelie 26 gasoline engine propels the Baja 5SC to speeds in excess of 40mph. With a dual-element air filter, easy pullstarting and convenient Torx T-27 screws, it's easy to keep running on standard pump fuel and 2-cycle engine oil. And best of all, you can run for more than 45 minutes on a single tank of gas!
VISCOUS TORQUE DIFF
From the input shaft and idler gear to the alloy-encased differential, every gear inside the sturdy Baja 5SC transmission is made from long-life alloy to keep your truck running all day long with minimal maintenance.
8,000 RPM CLUTCH
Standard on the Baja 5SC, this lightweight racing clutch combined with the heavy duty spring gives the 5SC a powerful launch at high RPMs for faster acceleration!
For runtimes of up to 45 minutes, the Baja 5SC fuel tank holds up to 700cc of pre-mixed fuel - that's over half a liter! And just in case you clip a track barrier and flip over, the tank is equipped with a 'clunk' device that allows the engine to continue running even if the truck is resting on its roof.
SFL-11MG SERVO
SEALED RADIO BOX
DIRT GUARDS
The Baja 5SC has full-length dirt guards to keep mud, rocks and water out of the main chassis area. The guards continue all the way to the engine and help keep cleaning time to a minimum. And, mud flaps on the rear bumper add to the realistic Short Course appearance.
VISCOUS TORQUE DIFF
SFL-11MG SERVO
SEALED RADIO BOX
DIRT GUARDS
BAJA 5SC FEATURES:
FUELIE 26 ENGINE
VISCOUS TORQUE DIFF
8,000 RPM CLUTCH
SFL-11MG SERVO
SEALED RADIO BOX
DIRT GUARDS
pepinov- Mensajes : 130
Bueno, ya tengo decidido... me voy a comprar el 5sc RTR, solo falta que esten disponibles en la pagina.
MUCHAS gracias
MUCHAS gracias
Bueno pués haz atención al comprarlo si lo compras en chacal rc, no te olvides antes de comprarlo de pedirle los bonos de descuento para que en la hora de la compra puedas tener el 10%.
Holaaa, Si, muchas gracias Rhacco, ya me envio el codigo para el descuento del 10% la verdad te ahorras una pasta, ya os contare cuando lo compre lo que me pieden pagar en la aduana de canarias... miedo me dan .
Gracias y saludos
Gracias y saludos
claro y que no se te olvide presentarnoslo jeje
nunca, os hara hasta si hace flata un unboxing XD.
PD: mirando precios mire en la pagina de traker de la cual me sale una duda. sabeis el motivo por el que se niega a enviarme un baja?
Hay muchas tiendas que no envían a canarias, lo que no se es por que...
De hecho, hasta entre particulares es un rollo, ya que hay que poner ambos dni para mandar cualquier tonteria
Pero esto no es en cuerta medida una discriminacion? si vende online y estoy dentro del territorio español y yo voy a pagar los costes de dicho envio que clase de problemas hay? la verdad ya tenia pensado comprar en chacal y de hecho lo hare en dicha pagina, pero me a tocado un poco las narices este tema.
Hombre Peter... ese ejemplo no es el mismo, ya que entre paises si es normal, pero hablamos de comunidades dentro del territorio Español. Tendre que informarme hasta que punto es legitimo esto... a mi es que me gusta bastante tocar las narices.
pues muy facil, no tributan al fisco igual que en la peninsula asique si tu envias o recibes se deven reajustar los impuestos. Casi casi hoy en dia se pueden considerar como un estado independiente de la union.
